mawebb said:The five gallon tank is inside, under the sink on the S model. The tank can easily be seen in the cupboard below the sink
2007 T@B
Rockford, IL
2007 T@B
Rockford, IL
Ok. here is the link:
http://www.customroto.com/rvtank.asp?ID=293
The person I spoke with is:
David May
Custom Roto-Molding
Phone: 208-459-1944
Fax: 208-459-1890
I purchased tank W-431but with hindsight being 20/20 I think W-33 would have been an easier choice from mounting standpoint I would have also changed the openings on the water tank a bit. I have inserted the file from the Yahoo forum for your reference where Peter Buck gave me many ideas used in my mods.
I used 2" by 1/4 angled aluminum to mount my tank to the frame. Our tab is a 2007 Dutchman. My water project was part of a larger modification where I moved the AGM batteries to the wheel well in a vented box. Then I added a wooden small box in front of the battery/propane carrier. This wooden box has the gravity water feed and city water connections. In the battery/propane compartment I installed a larger water pump, and tankless water heater. In that battery compartment there are bypass valves for the hot to direct to the outdoor shower or to the inside of the tab. there is also a bypass valve for the city water or the water tank. I replaced the faucet in the tab too. If there is further interest, I should create a different thread to discuss in more detail.
Have fun!
John
2007 T@B
Rockford, IL
Call Elsie in the Pleasant Valley office. She'll be able to tell you the price and get you any other info you need. The phone number is on the right under contact numbers.ChanW said:Does anyone know if LG will sell/ship their new 10gal tank for people to retrofit on a 2014 model? Seems it would be a fairly simple plumbing modification.
I think all the new t@bs have 11 gallon fresh water tanks. My 2015 has 11.......as I found out here.Patti said:This is good to know and I may come back for the details. We're looking at a new T@B that according to the website is only 5 gallons. The price is good enough to do it even though we'd rather have the larger, of course. Did you take out the 5 gallon?jcfaber1 said:I added a 10 gallon tank underneath our 07. It is great to have. There is a person on the Yahoo forum with great photos of the upgrade. I could elaborate if there is interest.
John
2007 T@B
Rockford, IL
2007 T@B
Rockford, IL
Not surprised. A month ago we stayed at a place, no water, not even the toilets. They brought in porty pottys. Next month the place we are going has zero water again. I noticed you carried extra water so I started doing the same.PXLated said:Rad - That campground I hit up in the redwoods (south of Half Moon Bay) had shut off the water except for the bathrooms - showers were off also.
