How accurate is the tongue weight ?
mreric
Member Posts: 154
Anyone actually measure the tongue weight on the CS-S? was it pretty accurate to what the website said? is that with water or without?
It is without water, the battery, or propane, I believe.mreric said:Anyone actually measure the tongue weight on the CS-S? was it pretty accurate to what the website said? is that with water or without?2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
Anyone measure with water ? I read a post someone said it only added 4 pounds after adding water.0
Since the water tank is over the axle, the tongue weight does not change much at all. I don't know if it is exactly 4 lbs different.mreric said:Anyone measure with water ? I read a post someone said it only added 4 pounds after adding water.
2016 T@b 320 CS-S - 2018 GMC Sierra - St. Catharines, Ontario, Canada0
