Alde water problem
i just drove 200 odd miles to a new campsite. It has 50 amp service only, which ive never used, so i usef the dogbone connector. I hooked upelectric and wayer and took the dog for a walk to return to a motor noise and water flowing from under the trailer. I turned off the water and it stopped.  No water inside, none anywhere under the seats, around the Alde drains inside. But from the evidence under the trailer it appears to have been coming from the yellow flap outlet. Why? What happened? I thought something might have shaken loose. The Alde was and still is off, by the way.
2018 T@B 320 Boondock
2018 Nissan Frontier
Kennebunk, ME USA
    Did you use a pressure regulator?
    If the pressure is too high, that yellow valve will open and water will drain from it. It's designed that way to protect the Alde.
    Others have reported the same issue. If it doesn't stop even with a pressure regulator, the yellow valve assembly may be faulty.
  • Jaxie985
    Jaxie985 Member Posts: 49
    That’s what I hoped!! No, I didn’t use a pressure regulator—my plastic one leaks and I haven’t gotten a brass one—but I will!!
    Kennebunk, ME USA
