Battery Charge
When my Tab 400 is in winter storage, I do not have access to an electrical outlet to keep the battery plugged in.     I also cannot remove the battery because I live in a condo.    I am going to use a generator to charge up the battery.     I am wondering if there is a charge time difference between plugging the trailer directly into the generator or plugging a battery charger into the generator and connecting to the battery posts.   Thanks!
2019 Jeep Cherokee pulling a 2018 T@b 400.
Victoria, British Columbia.
  • N7SHG_Ham
    N7SHG_Ham Member Posts: 1,261
    I would charge it fully, disconnect the battery with the big red battery disconnect and not worry about it. If you do decide to charge a high quality battery charger Direct to the battery should work better than the WFCO converter.
    2019 T@B 400 Boondock Lite
  • Marceline
    Marceline Member Posts: 1,768
    If it's stored outside there are small (10w) solar panels that will trickle charge the battery to keep it topped up.
  • DanL
    DanL Member Posts: 20
    Hello Marceline.     This is a good idea.    Do you have to leave the storage compartment door slightly open to allow the wires to get to the battery?
    pthomas745 Administrator, Moderator Posts: 4,654
    The batteries, if not under any load, will hold their charge for a long time.  The "self discharge" of is very low.  N7SHG has the right idea.
    Find the comments here about self discharge of batteries:
    @DanL, as pthomas45 stated, your AGM batteries in your 400, once fully charged, with the battery switch off, will last all winter with limited discharge.  You don’t even need a solar trickle charger.  Just check it once in a while for your own peace of mind and to prove to yourself that your battery is adequately charged.
  • Michigan_Mike
    As people have noted the battery should be fine for the winter when fully charged and with the battery switch in the off position.  A fully charged battery has a freezing point around -80 °F while a discharged battery has a freezing point around 20 °F. By keeping the battery fully charged during the winter months, the electrolyte is less likely to freeze and cause unexpected failures.  That's what I do to all my batteries here in Michigan, I charge them up fully, leave them intact (no current draw from anything) in the equipment and have not had any issues after using them in the spring.
    As for using a small solar panel, Zamp makes a solar port that can be install anywhere on the trailer and would allow you to plug the panel in and out as needed.
    https://youtu.be/FCfPvS6iTzk?t=17
    All good advice.
    Also, I have a feeling running a generator at your condo is not going to endear you to your neighbors.  ;-)
  • BirdieJane
    BirdieJane Member Posts: 237
    We had an AGM battery failure do to cold last weekend. Battery went from a full charge to nothing in 3 hours after the temp dropped. Check into it. Renogy is sending us a new one.
    not sure how cold it gets where you live, you might want your battery stored in a warm place.
    2017 T@B Outback white w black trim / 2019 Subaru Ascent White with black trim / Birch Bay WA.
    aka BirdieJane towed by Quinn
