Shore power, yes. Usually plugging in a DSLR camera battery, laptop, or cell phone...nothing drawing a lot of power.Awca12a said:What do you have plugged into the GFCI when this happens. Are you on shore power at that time or not?
I don’t recall how many were in the 320? Is the one above the sink just are receptacle and without the GFI? You are probably right as the GFI can used for used to protect other receptacles along a circuit.ChanW said:@Michigan_Mike, do you have more than one GFCI outlet in your Tab?
I'm pretty sure ours only has the one, under the bed, which protects all the other outlets on the circuit.
But @jkjenn, you could try them on a GFCI outlet in your home...
