T@b 400 Bin Mod
BigGrover
Member Posts: 450
Bought a piece of wire shelving to make a back for the bin. Now I can toss loose things like chocks, sewer elbows etc. In there without losing them. BigGrover
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama
Central Alabama
Excellent use of premade shelf! Just what you needed.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Yep, it had a lip that I cut off with bolt cutters. The propane tank, because of its shape, bulges out the back opening slightly so I had to remove a few pieces of wire for that. Cut opening for the propane hose so it's not in contact or rubbing against anything. Used some self tapping screws and nylon wire clamps. All parts came to $24 at Lowe's.BigGrover
Central Alabama -
Good idea! I have this on the list of eventual mods I want. right now I keep a 5 gallon bucket next to my propane tank to hold hoses, etc.N@VENOTSE
2019 T@B 400 Boondock Lite
SF Bay Area -
Great idea, BigGrover! What is the floor of this area made of?gande
2018 T@b 400
2019 Ram 1500 crew cab / 5.7 V8 -
Adding this to my mod list. I installed a bungee net in my tub to corral chocks and stuff but this looks like it would expand the storage space.John and Henrietta, Late 2016 T@B S Max in Western New York
@BigGrover That is brilliant. When the snow melts I can't wait to see if I can duplicate that. Thanks!
Pam and JohnChamplin, Minnesota2018 T@B400 and a 2025 Ridgeline Trailsport
@BigGrover
Another genius idea. I've been prowling Lowe's looking for likely objects with which to contain loose "stuff." It never occurred to me to use wire shelving, but it is a perfect solution! -
I had to buy a 5' section. It measured 17" wide which was perfect. I had them cut it at 32" since they had a hydraulic cutter. I could have left the lip on it but used bolt cutters to clip it off and that left some edges of wire I just bent over the cross brace.BigGrover
Central Alabama -
Smart!2017 T@B Max-S, silver & silver, towed by a Titanium Silver 2018 Kia Sorento AWD V-6, Twin Cities MN
- 919 Introductions
- 406 Service/Maintenance & Recall Notices
