Back board replacement or upgrade?
TerryV6
Member Posts: 1,101
I guess this kind of fits in this catagory. My 2016 T@b has the long 1piece rectangular board that covers the heat vent below and also the gycol resevoir. Ours warped somewhat. I did a mod and added some baskets in this area. I cut the board in two and added hinges. I'd hoped that this would tame the warp. The boards still don't lay/lie* (whatever) flat. My question is: would you order replacement from the factory to get the same fit and finished look, but now in the two piece that they use? Or... buy a board replacement from Home depot or somewhere and cut it yourself. The second option would certainly be cheaper. I'm not sure I could find a replacement that would match the original look. If I did the factory thing, I'd be hoping to order it and pick it up during the rally, thus ducking the shipping costs. Thoughts?
* I was taught that chickens lay and people lie down... I think thats how it goes anyway....
Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
Hi @TerryV6, I am not sure how many issues there have been with warping radiator covers for the TaB, but I can tell you that our home radiator covers made with MDF have not warped. Maybe you can find 2 shorter MDF pieces. Also, not sure what it would cost or how it would hold up with the relatively lower heat of the TaB radiator, but maybe consider 2 shelves covered with Thermofoil?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
@TerryV6, yea ole woodworker says to order a new board from nüCamp (easiest for the non-woodworking public), and cut it to the size needed.
ASAP cut it to the size required to your application to keep it from warping. Personally, I cut mine to 3 pieces, which should eliminate any further warping.Verna, Columbus, IN
Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”2
