ballpark weight of tab 320S (with refrigerator, stove, LP, battery)
Hi very new to the forum, 1 day old!  Can anyone tell me a good trailer weight for the tab 320S?   Ie adding weight of refrigerator, stove, LP, battery ?   Has anyone weighed it empty just after picking it up from the dealer?   Just curious how much it weights (ballpark)?  Thanks
    pthomas745 Administrator, Moderator Posts: 4,674
  • forgalsus
    forgalsus Member Posts: 10
     Here's the response to my question from NUCAMP.  "Great question, you are looking around 1985lbs with a full fresh tank" (for TAB 320S)
  • splatmatt
    splatmatt Member Posts: 29
    forgalsus said:
    "...full fresh tank" (for TAB 320S)
    are you referring tow weight including a full tank of water?
    Previous: 2018 T@B 320 S (Sprout)
    Current:  2020 Airstream Bambi 20FB (Pearl)
    TV: 2019 Chevy Silverado (Rhubarb "Rhuby" 1500)
  • lkc001
    lkc001 Member Posts: 881
    or a full fresh propane tank?
    2018 Tab 400
  • BrianZ
    BrianZ Member Posts: 1,770
    2018 320S specs list "Total Weight w/LP & Battery:  1,848 lbs", and 200 lb tongue weight.  If you fill the 11 gal fresh water tank, then add 88 lbs, so 1,936 lbs.  GAWR is 2900 lbs, so you can carry up to about 900 lbs of your own stuff.
    -Brian in Chester, Virginia
    RV: 2018 T@B 320S, >100 mods
  • forgalsus
    This was my question to NUCAMP...Can you tell me how much the TAB 320 S weighs with refrigerator, stove, LP and battery included?   Nucamp's response :"Great question, you are looking around 1985lbs with a full fresh tank "   So I'm assuming with a full tank of water.  Hope that helps
  • BrianZ
    You're welcome!
