ballpark weight of tab 320S (with refrigerator, stove, LP, battery)
forgalsus
Member Posts: 10
Hi very new to the forum, 1 day old! Can anyone tell me a good trailer weight for the tab 320S? Ie adding weight of refrigerator, stove, LP, battery ? Has anyone weighed it empty just after picking it up from the dealer? Just curious how much it weights (ballpark)? Thanks
Towed by 2014 Touareg TDi1 -
Here's the response to my question from NUCAMP. "Great question, you are looking around 1985lbs with a full fresh tank" (for TAB 320S)
2 -
or a full fresh propane tank?2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab0 -
2018 320S specs list "Total Weight w/LP & Battery: 1,848 lbs", and 200 lb tongue weight. If you fill the 11 gal fresh water tank, then add 88 lbs, so 1,936 lbs. GAWR is 2900 lbs, so you can carry up to about 900 lbs of your own stuff.
This was my question to NUCAMP...Can you tell me how much the TAB 320 S weighs with refrigerator, stove, LP and battery included? Nucamp's response :"Great question, you are looking around 1985lbs with a full fresh tank " So I'm assuming with a full tank of water. Hope that helps
You're welcome!-Brian in Chester, Virginia
