water pump
camper
Member Posts: 1
Last fall I was winterizing my trailer but when I turned on the tap the pump kept running after I closed the tap.It did not do that the year before.Was wondering if there are two pumps in trailer.If anyone can tell me why this happened and info to repair it.I think I cooked the pump.trailer open range 268 fifth wheel year 2017
Hi @camper, you joined the TaB RV Forum. Am I understanding that you are asking a question regarding your fifth wheel?
Are you saying that when you winterized, your pump kept running with the tap closed? Did you need to unplug the pump to stop it from running or did it eventually stop on it's own? If you were able to use the pump to instill antifreeze into your plumbing, sounds like it was working up to that point?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
