Fastway e2 WDH Installation
falcon1970
Member Posts: 758
Has anyone installed a Fastway e2 WDH? I ordered one and also ordered the 4 3/8" inside and outside link plates that equalizer sells for the BAL/Norco frame size. I was surprised to find that the bolts needed to install the L-brackets were not included. Have any of you ordered this set-up? Did you get the bolts with your order? I guess I just assumed (yeah, I know) that the speciality link plates would be fabricated like the original link plates with the bolts welded to the link plates. Looking at the website again I received exactly what they show in the pictures (no pre-welded bolts) but see no mention that extra bolts would be needed or any place to order them.
Check out this thread. A couple people have installed the fastway....seems to be one of the best options for the T@B.
https://tab-rv.vanillacommunity.com/discussion/6219/tab-400-weight-distribution-hitch-not-recommended-due-to-c-channel-construction/p4
The bolts are not included with the link plates. You have to order them separately.falcon1970 said:Has anyone installed a Fastway e2 WDH? I ordered one and also ordered the 4 3/8" inside and outside link plates that equalizer sells for the BAL/Norco frame size. I was surprised to find that the bolts needed to install the L-brackets were not included. Have any of you ordered this set-up? Did you get the bolts with your order? I guess I just assumed (yeah, I know) that the speciality link plates would be fabricated like the original link plates with the bolts welded to the link plates. Looking at the website again I received exactly what they show in the pictures (no pre-welded bolts) but see no mention that extra bolts would be needed or any place to order them.2019 T@B 400 Boondock Lite
2019 Chevy Colorado Z71 Duramax0
