Window shade string problem
Carlimmen
Carlimmen Member Posts: 10
Avoid having window shade string problems by not grabbing the outside part of the window shade while operating window shade. Your fingers will grab the string causing it to come loose from the track.
  • Homebodyatheart
    @Carlimmen if you use the search function I’m pretty sure you will find instructions on fixing the strings. I remember this as an issue for someone once. Good advice!
  • klenger
    klenger Member Posts: 309
    I have a window that came "unstrung" some time ago and would like to fix it.  If someone has a specific link to the repair instructions, I'd appreciate it.  Someone did post a link to an installation document that I found, but not repair.  Tx
    Wasn’t @Mouseketab a resource for that?
  • Carlimmen
    Thanks homebody at heart. My wife and I were able to repair it after searching the forum.
  • mjpalmer
    mjpalmer Member Posts: 20
    Hi there.  Where did you find the instructions to fix your window shade?  Our string just broke on our privacy shade for the stargazer window in the back.  Any help would be appreciated :)
  • schout
    schout Member Posts: 29
    Thanks!  We had a string come out of the track this weekend!
    2021 T@B 320 S Boondock
    2020 Toyota Highlander
  • mjpalmer
    Thanks so much for the info!  Much appreciated :)
  • Mouseketab
    Not me, have had no problems with my shades.
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • rbrtm
    rbrtm Member Posts: 34
    Are the strings even necessary? My shade binds up where the strings cross each other
