Window shade string problem
Carlimmen
Member Posts: 10
Avoid having window shade string problems by not grabbing the outside part of the window shade while operating window shade. Your fingers will grab the string causing it to come loose from the track.
@Carlimmen if you use the search function I’m pretty sure you will find instructions on fixing the strings. I remember this as an issue for someone once. Good advice!2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red
I have a window that came "unstrung" some time ago and would like to fix it. If someone has a specific link to the repair instructions, I'd appreciate it. Someone did post a link to an installation document that I found, but not repair. TxT@B 320 manuals and electrical drawings
2023 Jeep Gladiator Sport S, Max Tow Package. -
Wasn’t @Mouseketab a resource for that?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Thanks homebody at heart. My wife and I were able to repair it after searching the forum.
Hi there. Where did you find the instructions to fix your window shade? Our string just broke on our privacy shade for the stargazer window in the back. Any help would be appreciated
This will help.
https://tab-rv.vanillacommunity.com/discussion/2114/blinds-shades-assembly-instructions
Thanks! We had a string come out of the track this weekend!2021 T@B 320 S Boondock
2020 Toyota Highlander -
Thanks so much for the info! Much appreciated
Not me, have had no problems with my shades.Sharon_is_SAM said:Wasn’t @Mouseketab a resource for that?Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL -
Are the strings even necessary? My shade binds up where the strings cross each other
- 917 Introductions
- 73 Teardrop Groups & Links
