Replacing the step
Jenn, I’m using cedar steps I got at a rummage sale last fall and love them! Many have used hot tub steps, too. I find having two steps is easier on my aging knees.
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1 -
@jkjenn, I highly recommend the new step used on the 400’s. It doesn’t flex and bend and no rust. I think Austin has figured out how to get the nice light above the step on the 320’s. Ask Jasper Pendry, as I think he was the first to get the mod on his 320..Verna, Columbus, IN
Thanks, will do!Verna said:@jkjenn, I highly recommend the new step used on the 400’s. It doesn’t flex and bend and no rust. I think Austin has figured out how to get the nice light above the step on the 320’s. Ask Jasper Pendry, as I think he was the first to get the mod on his 320..
Thanks, but the last thing I need is one more thing to pack!Homebodyatheart said:Jenn, I’m using cedar steps I got at a rummage sale last fall and love them! Many have used hot tub steps, too. I find having two steps is easier on my aging knees.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
3 -
Two steps might be nice for your puppo.John and Henrietta, Late 2016 T@B S Max in Western New York0
He does really well with just one. He likes to jump...thankfully, he us light enough (15 lbs) to pick up as he ages.Photomom said:Two steps might be nice for your puppo.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
I’ve I’ve toyed the idea of getting the new aluminum step(s)...TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0 -
I got my dealer to agree to switch out the standard step with the new aluminum step on my 2019 320S BL. Unfortunately, after they removed the standard step, they discovered that only two of the four bolts line up with the mounting holes on the aluminum step. Thus, despite my successful negotiating for a better step, I had to leave with the standard version. I wrote to nuCamp at the time and suggested that they should make the aluminum step standard on all their campers, or at least figure out a way that a purchaser can select whichever version they want. It was a total bummer for me, because as @Verna noted, the aluminum step is much better.
Greg & Marlene (Tucson, AZ)3 -
Thanks....I might be sending Austin an email tomorrow for a quote. Thankfully, I am just a couple of hours from Sugarcreek.
The new step is shown near the end of Mandy Lea's video of the 2020 320.Richie, Mickie and Satchmo
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium0 -
This is not a cheap mod and I probably will not make it this year. When I have some time, I will check out the existing step and if it is easily replaced.
I hated the original step. I took it off and bought a standalone aluminum step. It's a huge improvement.
A us year or so ago I enlarged the stock step with a piece of 3/4” plywood. Bolted directly to the original step. Cost less than $10. An added benefit is that when retracted it still extends about 6”. So when traveling and we make a quick stop it’s easier to enter and exit without pIllini out the step. When parked I do support the step to reduce stress on mounting points.
- Hash T@B Fun
3 -
Does anyone have an idea of how much the new aluminum step cost for the parts?2018 T@b 400, 200ah Lithium with Solar
2013 Tundra TRD 5.7L
Massachusetts0 -
This might be worth having a look at:
https://www.etrailer.com/RV-and-Camper-Steps/Hickory-RV-Steps/951243EXTALC1.html
The guys at etrailer are pretty responsive, and you might be able to get the bolt pattern details from them.San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
@ChanW, here are the measurements:ChanW said:Does anyone have a photo of the aluminum step?
And dimensions of the mounting holes? (@bayliss, Frustrating!)
7 7/8” wide
20 1/2” long
And I do not know how to measure for the bolt pattern. That may be a question for tech@nucamprv.com.
If you need different photos, tell what you need to see.
The first photo is looking up at the step from the front of the step.
Towards the front from the left side of step as facing 400
From front of step, looking down the passenger side at my folded chairs
Looking downward at the stepVerna, Columbus, IN
Yeah, this is one that has been on my list. ThanksMarceline said:This might be worth having a look at:
The guys at etrailer are pretty responsive, and you might be able to get the bolt pattern details from them.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
The good news is that upon further inspection it appears that I do not need a new step, just a can of PB Blaster and a box wrench. It appears that the nut holding the step up on one side is lower than the other side. That should be an easy fix.
7 7/8” wide
20 1/2” long
............Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya1 -
Dalehelman, that is exactly what I've been trying to design. Would you be willing to share the specs on it? And what are you using to hold it up?0
@3leggedRoz
3/4” plywood cut 15”x 22 1/2” bolted to existing step. Because of the added lever you should use
Quick Products QP-JSS-4 RV Step Stabilizer (4.75" - 7.75")
Quick Products
$10.17
The one I used required some cutting and welding to make it short enough.
Camco Self-Stor Step - Mounts Under RV Steps to Stabilize Steps and Prevent RV Movement and Swaying, Lifts Up For Easy Storage After Use , One Time Installation (43671)
Camco
$17.56- Hash T@B Fun
