CSS
Imawanderer
How much does the Boondock lift the kitchen on the CSS? Will my 5'2" wife be able to utilize the rear kitchen without bumping her chin on the counter? 🙃
About 3-4 inches. I saw someone at uCamp that used a short step.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
She will definitely want a step / platform.
2016 T@b 320 CS-S - 2018 GMC Sierra - St. Catharines, Ontario, Canada0 -
I'm 5'0" and with a regular (non Boondock) clamshell I can't use the right side of the counter (over the fridge) for any prepwork. I imagine your slightly taller wife would have the same issue with slightly higher Boondock edition. I have a cover made out of HDPE that I put over the burners to use as a work surface. I suppose you could also solve the problem by taking over kitchen duty. 😆Imawanderer said:How much does the Boondock lift the kitchen on the CSS? Will my 5'2" wife be able to utilize the rear kitchen without bumping her chin on the counter? 🙃
But seriously, if you want to get a Boondock edition I would see if you can get NuCamp to build it with the T@G-style kitchen (flush counter, roll-out 12v cooler). I think that's how NuCamp should be building these, anyways.
Work surface made from King StarBoard HDPE
Me at the kitchen. You can see that the right side is too high to use as work surface.San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
- 144 Events & News
- 415 Service/Maintenance & Recall Notices
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
