where is temp sensor for ac? does not cycle when outside really hot. but trailer is very cold.
Tundra57
Member Posts: 640
Used ac on hot day, 95 outside. Set ac to 74. Left for couple hours. Came back, trailer ice cold. Compressor still running. Set temp to 78, still running, temp inside was way less than 78.
In the evening, 74 setting worked great, cycling on and off as expected. Fan set to auto.
Where is temperature sensor? Maybe temp sensor was not getting as cold as the rest of the trailer.
Worried if on generator, might burn gas too quick.
Good news is ac works really well.
It is at the door within the Dometic control and it is exposed to heat resulting in excessive cooling. Try setting the temp higher during the day.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Makes sense thanks.
- 916 Introductions
- 72 Teardrop Groups & Links
