Refillable Propane Tank
Does anyone use small (1lb) refillable propane tanks that can be used for propane stoves/grills/lanterns...etc.?  Seems like it would be cheaper in the long run and reduce waste with the empty 1lb tanks.
https://www.amazon.com/Flame-King-Refillable-Propane-Cylinder/dp/B07F9LCYRT/ref=sr_1_2?keywords=empty+one+pound+propane+tank&qid=1565814034&s=gateway&sr=8-2
2017 T@B 320S, 2011 2WD Honda Pilot, Coming out of The Woodlands, TX....Mark & Carolyn
    edited August 2019
    FWIW you can do this with pretty much any 1lb cylinder once you have the adapter. However, there are limitations to the practicality, safety, and possibly legality of reusing cylinders not intended for the purpose.
    The rig you show seems a little fancier--and pricier--then the adapter that is commonly available, so maybe it addresses these limitations and might be worth the extra dough.
  • JEB
    JEB Member Posts: 268
    Yes.  I use them. They’re great and they’re legal to transport.
    2019 T@B 400 Boondock Lite
  • klenger
    klenger Member Posts: 309
    Get a 1 gallon / 5 pound tank and you can get it filled at any LP dealer.  I think to total weight filled is about 11 lbs.  Camping World has a really nice one.  Expect to pay a bit of a premium for it's size.
  • Homebodyatheart
    Yes, for my Coleman stove snd Little Red Campfire. Bought it at my local hardware store. Love it!
  • db_cooper
    db_cooper Member Posts: 749
    I bought the flame King refill kit and it works fine. Can definitely fill the tank fuller than I've been able refill the disposable ones that don't have a vent.
  • pepper
    pepper Member Posts: 4
    We use a one gallon tank also.  I bought mine at Home Depot.
  • dCliffhanger
    dCliffhanger Member Posts: 120
    Instead of using separate small bottles, I substituted a "T" valve splitter to my main 20# tank and an addition 12 foot hose that connects to my camp stove wherever I want to put it.
    Ron\ 2020 T@B 320-S Boondock Edge; Roof Solar, Firefly Grp31 Carbon Foam Battery; TV: 2019 Grand Cherokee Trailhawk 3.6l V6; Madison, Wi
  • klenger
    I bought this one from Camping World.  They don't show any LP tanks on their website, but they have them in the stores.  I think I paid just south of $50 for it.  Very stable with the flat bottom.
    https://smile.amazon.com/Refillable-Steel-Propane-Cylinders-4-5-gal/dp/B003RWADZA/ref=sr_1_10?keywords=5+pound+lp+tank&qid=1565931420&s=gateway&sr=8-10
  • wooper
    wooper Member Posts: 75
    @klenger do you refill it from a 20 gal tank or take it someplace to fill it?
  • davel4wa
    davel4wa Member Posts: 91
    edited August 2019
    Most of the comments here seem to be ignoring the fact that is illegal to refill the regular 1 lb. cylinders you buy at your favorite store.
    https://youtu.be/g2_GhyAw3vM
    Could never happen to you, right?
  • klenger
    I have it filled by the same gas station that fills the 20# tanks. See post above this one regarding refilling your own tanks.    I travel with LP on much of time (no flaming please) but would never consider refilling my own tanks.
    Good discussion. I'm revising my earlier comment to be clear that I'm not necessarily advocating the reuse of disposable cylinders.
    Commercial refilling of 1lb disposable tanks is illegal, but it's unclear if the same law applies to doing so for personal use. Same applies with regard to transportation on public roads--relevant here since the point of having a camper is to be able to take it somewhere. Local regulations may also apply.
    I "know a guy" who recently refilled a few bottles with limited success... ;-)  If you follow the directions exactly you can only get them ~3/4 full. Also, while the cylinders themselves didn't leak post refilling, one wouldn't properly seal up with the appliances.
    In light of the legal ambiguity--not to mention to common sense safety issues--the 1lb cylinders designed for refilling strike me as a good investment. While I also use a T-adapter and hose off my 20lb T@B tank, I still like the flexibility of the small cans for some applications.
  • wooper
    davel4wa  I wasn't considering on refilling disposable 1 lb tanks, but using the tanks that are designed to be refilled.  I just think its a waste to keep buying and throwing away these small tanks.  I could use a splitter or other methods, but if I want to have my grill, stove, lantern, etc.  someplace away from my 20#, smaller tanks are the answer.  I don't want to break any laws...just looking for a reasonable, environmentally safe option.
  • ChanW
    ChanW Member Posts: 3,171
    That's a good reminder of what I don't know... Thanks.
    Chan - near Buffalo NY
    2014 S Maxx (ie: "320")
  • ChanW
    edited August 2019
    Note that they also sell just the refillable 1# cylinder, without the 'kit', if you happen to already have the refill adapter. Much cheaper, @ $11.
