Loud water pump
webers3
Member Posts: 436
Is it normal for the water pump to sound like a jack hammer?
2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut
Normal is relative, but he short answer is yes.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0 -
@webers3, if you add some water pipe insulation foam around the shower water pipes (behind the panel to the left of your television), you can reduce a lot of the "jack-hammer" noise. The padding prevents the pipes from banging against the wall when the water pump is operating.
2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Ours was sounding like that. We cleaned out the filter attached to the left side of the pump. There was some debris in it. Can't hardly hear it at all now.2018 T@B 320-S / 2007 Toyota Tundra
Harpers Ferry, WV1 -
If there is rigid piping in/out of the pump, you can also install some flexible hose on both sides of the pump, and some rubber isolation washers (if not already present) to help quiet the pump.1
- 120 Dutchman and Vintage TaB Archives
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
