Fridge Question
PoodleMayhem
Member Posts: 11
I have a 2017 320 with a 3-way fridge. I plugged into shore power earlier to charge my battery. When I went out a few minutes ago, the fridge sounded like it was running (not cooling, but running). Power switch is off. What’s happening and how do I make it stop?
Laura
2017 T@B 320 S / 2017 Jeep Grand Cherokee
Santa Fe, NM
3 nights and counting...
Santa Fe, NM
Is your frig set on DC? Sure it’s turned off?
https://us.v-cdn.net/5021717/uploads/editor/km/hagzgl7hkh71.pdf
Yes, definitely off, which is what made it so perplexing! I ended up unplugging from the house for a bit. I just reconnected. Will go back out shortly to check on things.Laura2017 T@B 320 S / 2017 Jeep Grand Cherokee
Santa Fe, NM
3 nights and counting...0 -
Could it be the fan in your power convertor under the driver's side bench? That always runs when I plug in.Mike and Lisa Campbell
Springfield, MO
2016 T@B Max S - Sold March 20200 -
Is it possible there is some kind of frig fan that is running independent of the frig? The converter fan noise is more mid-TaB, I would not expect for it to sound like it is coming from the frig. Is there a separate frig fan switch in the 2017s? Or, is the accessory A/C fan still on?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
It was definitely something with the fridge. Sounds like I need to investigate further.Laura2017 T@B 320 S / 2017 Jeep Grand Cherokee
Santa Fe, NM
If you have the fridge with the aux fan (fan switch on the right side of the fridge panel, and a vent on the passenger side) that could be the fan you hear running. Look for the green light.
Towed by 2014 Touareg TDi1
- 421 Service/Maintenance & Recall Notices
