First post... be gentle! Our new 2019 T@B 400 w/factory solar seems to be losing battery charge. The battery went from 83% to 75% overnight. The fridge, radio, AC, Alde, as well as all switches and lights, are off. The only things that seem to be on are all the idle lights, usb power, tv, Co2 monitor, etc. These numbers are from the iPhone app for the bluetooth solar controller, fyi.
Does this seem like a normal drain or should I be looking for something not so obvious?
Thanks-
Peter
Peter & Darlene
"Sparky" 2019 T@B 400
2017 Honda Ridgeline RTL-T
Flagstaff, AZ
0 ·
2013 Tundra TRD 5.7L
Massachusetts
Solar is new to me so please excuse my noobyosityness. This raises a question in my little head... If I use the battery disconnect to disconnect the battery will the solar controller still connect with my app? I'm guessing no, even if the solar is making power. So... to read my battery I'll need my volt/ohm meter to measure it. I guess this is why people install wired remote battery meters rather than just an app. One other question... If I disconnect the battery with the disconnect will it not charge with shore power as well? I'm guessing no as well.
Thomas745- I'm not really sure what a "rested" state is. Unless it's disconnected, voltage is either going one way or the other it would seem!? Please explain...
Scott G - I think the voltage this morning was 12.6. I don't remember last night. I am going to start doing some serious testing however with the battery connected and disconnected. The solar is seriously compromised as "Sparky" is covered in a PahaQue cover. It does punch it up, even still, about 8-10% every day. If we could just get some decent sunlight here during cloudy monsoon season it might even make it to 100%.
Flagstaff, AZ
I know on my 2018 400, the factory solar PWM wiring is directly between the battery and solar panels, so even with the T@B disconnect/cutoff switch is turned off, the battery is still getting a charge from the solar panel if the panel is indeed able to develop a charge.
So I feel to get a true SOC or even to test a battery at rest is a bit of challenge if a factory solar panel is connected directly to the battery.
Now I figure if the PWM fuse is pulled, then the PWM will not be electrically connected, but where the 2018 400 is located, under the bed near the Alde, it is both a PITA to read and be able to pull its fuse and re-insert if one would do that. Note: Myself I rather not be pulling the PWM fuse for any reason unless one wanted to truly reset the PWM for any reason.
Utah Driven
2019 T@B 400 (Ex 2018 400)
2015 MB GLK 250 Diesel
2018 GMC Canyon Denali Duramax CCSB
I do see what you are referencing. The junction box battery + is indicated to the battery. And the converter to cutoff to Battery +. so a loop is formed.
Renee got this for me when I asked for the wiring diagram for my 2018 400.
I have validated the cutoff switch to the converter. I have not validated the junction box Battery + to where that lead(s?) goes to.
But as an educated guess, I bet the junction box Battery + only goes to the converter and jumper to the E-Brake. Why - the E-Brake gets its power from either the TV or converter and if the power is from the converter, we know the cutoff switch must be on.
Just took a short drive, nothing like a drive to think clearly LOL
I bet nüCamp intentions on the junction block was to just label the connections, not to directly indicate where or how the wires got to points within the trailer.
Utah Driven
