I've had my Gidget (2018 T@B 320s) since June 1; two and a half months. She has been camping four times. I noticed right away that every time I removed shore power, a blowing noise emanated from the a/c area. Since it did it every day, I thought it was some sort of normal exhaust.
Last weekend when I attempted to go camping, I noticed the battery was completely dead when my electric tongue jack simply would not turn on. Got it jumped and went on my way. Three days after returning from camping, and not being on shore power, the noise from the a/c area has stopped and so has my battery. Obviously, that's the cause of the power drain but I have no idea how to figure out what on earth that blowing noise is. The a/c is off (doesn't work without shore power anyway) so what is in that area that's killing my battery???? Please give me some idea so I know how to intelligently tell my dealership what's needs to be fixed. Thanks so much, as always, for any assistance you can offer.
Look out open road, here we come!!! Me, my Gracie May, a 2YO Beaweenie; half Beagle, half Dachshund, Dash, the 2015 Kia Sorento LX V6, Gidget, the 2018 nüCamp 320s!
0 ·
Once you get a new battery, hook up to shorepower and turn on the battery cut- off switch to charge the battery. Then, with storage, make sure everything is turned off and isolate the battery by turning the cut- off switch to off. That way, those items with phantom draw will be turned off so your battery does not drain.
PS - @ScottG, nope, no voltmeter but thank you for suggesting that. I'll order one now. Any specific kind you recommend?
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
MOUSE-KE-T@B
Harvest, AL
MOUSE-KE-T@B
Harvest, AL
I realize this thread is a few months old, but thought I would add a couple of minor points..
First, about the A/C accessory fan, mine is wired to draw extra fresh air into the box to improve efficiency, not to exhaust, as previously mentioned. Here's a picture of it mounted on the underside of the roof vent - it's just a little computer type DC fan..
Without it, the A/C unit may struggle to bring in enough fresh air though that same side vent used mainly to exhaust hot air. You can see its wires going down to the switch.
Also, Scott had a good suggestion for getting a multimeter, which can be handy for other things besides checking voltage, like testing "continuity" to see if a fuse is bad. For battery voltage, you already have a built-in meter accessible by pressing the "BATT" button on the SeeLevel monitor next to the sink..
I installed a separate battery monitor above ours, and by comparison with that or a voltmeter connected directly to the battery, I'd say the SeeLevel voltage agrees to within less than about 50 millivolts, so quite reliable. This reading shows the battery at about 90+% charged, with battery switch on & converter unplugged from house power.
You should check it frequently to see what's normal when plugged in vs unplugged. Ours typically shows a 13.6V "float" charge when the converter is plugged in & actively charging, or after a couple of days & fully charged, it will drop back to 13.2V trickle charge. Hope this helps.
