Has Anyone Removed or Moved
the Certification Labels
Background
The certification seals are;
RVIA, CSA Z240, Washington State.
I do not know how many other
states use/require the Washington Seal the way many states use the
California Vehicle emissions standards
These two or three Seals are
placed right at the entry door. A nice front and center location
during the sales – marketing life of a new trailer. Not so great
once the unit is sold.
All three are Safety
Certifications not build quality certifications.
They insure the RV
is built to legal (or organization standards) requirements for strength, electrical, propane
usage and require the manufacturer to document their methods and
allow inspections by the Government or Organization.
Don't know for
sure but would guess RVIA also addresses things like location of
electrical, sewage, fresh water ports
RVIA is an manufacturers
organization and we buyers cannot read the standards.
Washington Seal requirements
are that the RV must meet Washington Laws (which we could research)
and the application/contract says the Seal must be affixed to the RV
at time of sale in Washington State.
Location is
not defined.
CSA Z240 is Canadian. Don't
know if it is Government or “UL” like. Testing for T@Bs
is completed by Intertek
Side note:
DOT/NHTSA required labels
like GVWR and Tire Pressure are required to be placed in a general
area which is not the front & center entry door.
How to Remove/Move ? ?
All three are the metal
style labels that tend to wriggle badly when removed (part of fraud
security? ) making smooth replacement difficult. Also don't know how
useful the adhesive would be for a second placement.
I've considered
photographing, removing, placing on paper, keeping with original
manuals.
Ideally would like to remove
– move to a location that is not front & center.
Any Thought or Comments out
there?
Seriously, if you must remove them (and I'm assuming your motivation is purely cosmetic) you might try a hair dryer to soften the adhesive and some fine fishing line worked behind the seal. This is a common practice for getting metal emblems, etc off bodywork, though I don't know how well it would word for something that is more like a sticker.
I'm pretty sure my 2015 only has the Intertek sticker.
Otherwise, test local enforcement by quietly cutting off a mattress or pillow tag late one dark, rainy night and then peer through the blinds to see if government officials with guns show up. If not, you may be okay...
Do like the Heat Gun & Fishing Line suggestion as a possible way to do the deed.
Did attempt to research the "Washington State Seal".
For new unit sales: Seems clear that for a manufacturer to build, sell, or lease an RV in Washington State they must apply for state certification by the Department of Labor and Industries. Primary goals of certification are to confirm RV design and construction meet Washington law/regulations. Which are basically references to National Safety Standard and USDOT for frame design, electrical, and propane. Manufacturer needs to track (transfer to L&I) assigned seal number and VIN data.
The fine print states the Washington Seal must be placed at least 10 inches above ground at the main door side opposite the hinges at time of leaving factory, sale, or leasing. So now we know why that label is Front & Center.
Washington DMV research on future private owner selling of RV.
As long as an RV being sold has a Washington State Title there are no additional inspection/standard requirements. Would guess in theory the VIN on Title could be traced back to original L&I documents provided by manufacturer if anyone really cared. Do a bill of sale, sign over title, pay a fee.
Believe Washington State does not have any yearly inspection requirements for RV annual tab purchases.
Will think on it some more . . . still long range planning on removing/moving them. Maybe attempt it on the Z240 (Canadian) 'seal'.
Have written e-mails** to WA-DOL and WA-L&IOffice of Factory Assembled Structures seeking additional answers.
As noted in early posting, DOL has no references to any inspection or seals for transfer of ownership.
For @ericnliz and Other Washington State owners
Some information from WA Department of L&I
In short; don't remove or alter the WA RV Seal.
Source:
FAS Plan Examiner
Washington State Department of Labor and Industries
Field Services and Public Safety
Some of his comments:
. . . at initial sale are to be reviewed and approved and be labeled. If the unit has a state label it is to remain and not be removed or it will compromise licensing, re-sale, etc.
. . . WAC 296-150R, available online, [has requirements “R” is the “RV” chapter] . . . there is no [Seal] removal options indicated (by not saying it, it does not imply its ok)
. . . . There is replacement options although [they] require inspections. I would suggest not going that route for issues of code changes that could possibly require updates etc.
Additional Notes;
from WAC 296-150R-0050
. . . it is unlawful for any person to sell, lease, or offer for sale a recreational vehicle within this state if it violates any of the requirements of this chapter . . .
from WAC 296-150R-0250
How do I replace lost or damaged insignia?
(1) If an insignia is lost or damaged after it is placed on a recreational vehicle and you are the manufacturer or owner, you must notify us in writing immediately.
(2) Your notification should include the following information:
(a) Your name, address, and telephone number;
(b) The vehicle identification number or serial number and model;
(c) The insignia number and design-plan approval number, if applicable; and
(d) The required fee. (See WAC 296-150R-3000.)
(3) If we can determine that your unit previously had an insignia, we will attach the insignia to your vehicle once we receive your insignia fee. (See WAC 296-150R-3000.)
L&I could of course not address the Trade Industry labels.
If very old age or death the plan is for my children to have to deal with it anyway.
The Heat Gun Method worked great. Also used some of my Car Interior Plastic Removal tools. Then placed them on a sheet of paper and will save with T@B papers.
I'm a rule follower, but at times . . . .
