Starting to think about solar...
Instead of one big solar panel (that would be heavy and an expensive loss if it were to go bad) I wonder if these would be a good choice. They are light, I could start with a couple of them and add one or two more later, and if one dies it wouldn’t be a huge loss. I assume you could connect them in parallel to get 100 or more watts.
https://www.renogy.com/renogy-50w-mini-eclipse-monocrystalline-solar-panel/
Thoughts?
    pthomas745 Posts: 4,645
    I think Jenn Grover has those panels.
    I have just one 100 watt flexible panel. Weighs just 4 pounds and stores anywhere I want.  I'm not sure I would want to chase around multiple panels, but that is just me.  Those Renogy's do look nice, though.
    And, sadly, due to the tariff situation all these panels have gotten a bit spendy.
  • jkjenn
    jkjenn Posts: 6,424
    Thoughts?
    I just picked up 4, recently. Hoping to test this weekend. Will give you some feedback I will also be taking them with me in Sept  I am planning on all dry camping and boondocking.
  • jkjenn
    jkjenn Posts: 6,424
    I am likely going to connect 2 in series, and then the 2 sets in parallel.
  • Photomom
    Photomom Posts: 2,217
    My feeling is a flexible panel just isn’t going to have the mechanical robustness of a fixed panel. I’ve heard of a couple of them going bad, most likely at an internal connection.
  • Photomom
    Is that to run your ARB on 24 volts?
  • jkjenn
    jkjenn Posts: 6,424
    No, 200w to replace my flexible.   Although, I am going to retest my flexible panels to make sure they really are bad.
  • jkjenn
    jkjenn Posts: 6,424
    Partial cloud cover
    Sharon_is_SAM Posts: 10,035
    @jkjenn, is that the flexible panels above?
  • jkjenn
    jkjenn Posts: 6,424
    No, the 4, 50w Renogy hard panels.
  • jkjenn
    jkjenn Posts: 6,424
    I have been watching these panels and not really seen much of a difference in price. Companies , like Renogy, are starting to roll out their next gen panels, which are a little more, but this customary until they have recouped R&D. The HQST panel I bought is $20 cheaper now than when I bought it 2 years ago.
