Overloading Your Axle
N7SHG_HamN7SHG_Ham Member Posts: 1,261
edited September 2018 in Trailer & Towing
This may be news to some, but a weight distributing hitch can overload your trailer axle, he is speaking of single axles, but it seems this would apply to all. His RV had what amounts to an inadequate Dexter axle from the get go, in relation to T@B trailers I wonder how the axle is sized? Spec sheet says 3500 pounds. He found that weight tag on the axle itself. https://www.youtube.com/watch?v=lVg8QgIFJoU
    I have to be honest, I have been alarmed at the rate at which people have been jumping on these without investigating other issues, like the way they are packing. first.
  • PieshobbithousePieshobbithouse Member Posts: 17
    You are dead on . Great point. Big vehicle small trailer and its a “s” show.
    2018 CS-S
  • MuttonChopsMuttonChops Member Posts: 1,880
    For anyone considering a Weight Distribution Hitch there is an excellent calculator web-site that shows you all the axle loading in a side-by-side format;  WDH vs WC.
    You do need to research your TV specifications and do a couple of measurements. You can then play with how much cargo (weight) you are carrying and tongue weight % to see how WDH helps or hurts your specific TV & T@B combination.
    Trailer Towing Calculator
    Weight Carrying vs Weight Distribution Hitches
    https://www.ajdesigner.com/apptrailertow/weightdistributionhitch.php
    Example Only
    of one of the outputs
  • JustJohnJustJohn Member Posts: 171
    I agree, these weight distribution hitches are unnecessary on a trailer this size given proper loading and a tow vehicle of adequate size to handle the load.
    We Tow level, store the cargo weight on the trailer axle or in front of it, and watch our speed, especially in high winds areas. Those measures are all easily within our control.
