Alde Manuals and Resources
ScottGScottG Administrator Posts: 5,654
Manuals and other resources for the Alde Compact 3010 and 3020 boilers.
    edited October 2018
    Typical Alde Fuse and Circuit Breaker Locations
    Description: Fuse and circuit breaker locations for the Alde 3010 boiler.
    Created by:
    Michigan_Mike
    Posted by: Michigan_Mike
    ALDE Fuse Location on ALDE unit
    edited October 2018
    Digital Control Panel Tutorial
    Description: Video tutorial for the use of the the 614 digital control panel.
    Created by:
    N/A
    Disclaimer: Resources provided by members are not necessarily endorsed nor approved by nüCamp. Models differ and configurations are subject to change at any time. Use at your own discretion.
    https://youtu.be/Jl8xNCs7xww?t=14
    edited October 2018
    Alde 3010 Operating Manual
    Description: Operating and installation manual for the US and Canadian Alde Compact 3010 boiler. Includes operation instructions for both the 614 (digital) and 314 (analog) control panels. Note: beginning in December 2017, T@Bs are equipped with the newer Alde Compact 3020 boiler. The 3020 operating manual is available below.
    Created by:
    Alde Corp
    edited October 2018
    ALDE High Altitude Regulator Installation
    Description: Detailed Instructions for the installation of the Alde high altitude regulator. Installation of the high altitude regulator on Compact 3010 models may mitigate excessive boiler noise common when operating the Alde at higher altitudes.
    Created by:
    ColoradoJon
    Posted by: ColoradoJon
    Disclaimer:
    edited April 2021
    Alde 3010 Service Manual (UK version)
    Description: Service manual for the Alde Compact 3010 boiler. Note that this is the UK version of the service manual. While the general configuration of the boiler should be the same, some technical specifications differ from Aldes designed for use in North America.
    Created by:
    Alde Corp
    Posted by: ChanW
    edited October 2018
    Alde 3020 Operating Manual
    Description: Operating manual for the US and Canadian Alde Compact 3020 boiler. Beginning in December 2017, T@Bs are equipped with the newer Alde Compact 3020 boiler. Upgraded from the Compact 3010 used in earlier T@Bs, the 3020 features a high altitude setting and has only one glass fuse protecting the 12V power supply. Note: Older T@Bs are equipped with the Alde Compact 3010 boiler. The 3010 operating manual is available above.
    Created by: Alde Corp
    Posted by: MuttonChops
    edited October 2019
    Alde YouTube Channel
    Description: Short instructional videos for operating and troubleshooting Alde boilers and components.
    Posted by: N7SHG_Ham
    https://www.youtube.com/user/aldeheating/featured
    edited April 2021
    Alde Glycol Brand Change
    Description:  Alde glycol for TaBs manufactured on or after 1/4/21 is now RhoGuard brand - RG-RTU-50 (RhoGuard Ready to Use 50/50 Mix) made by Rhomar Water.
    Listed purchase locations and product data and safety sheets.
    DIY Alde Glycol Exchange
    Description: Comprehensive instructions for changing the Alde glycol using an inexpensive manual transfer pump and simple homemade adapters. Access is via the top of the Alde expansion tank and requires no disassembly or modification.
    (See the full forum discussion of this topic here.)
    Created by: ScottG
    Posted by: ScottG
    edited April 2024
    Alde / Truma Contact
    Description:  How to contact Alde (now part of the Truma Corporation)
    Provided by:  KAR
    Posted by: Sharon_is_Sam
    Telephone:  (877) 860 9814Alde E-mail:  service@alde.usTruma E-mail:  service@trumacorp.com
    Alde Control Panel
    Description:  Quick guide to use of the Alde Control Panel
    Created by:  Alde
    Posted by:  carpense
