ALDE leak
JimTrish88
Member Posts: 14
Used ALDE for first time - fluid level above min line
Didn't work well on electricity, changed to Propane - worked good.
Next morning noticed yellow green fluid at front driver side corner
and reservoir empty.
Refilled tank and found leak - broken connection to reservoir tank and hose.
and reservoir empty. Refilled tank and found leak - broken connection to reservoir tank and hose.
2018 T@B CS-S towed by 2015 Kia Sedona
Brandenburg, Kentucky
What year and model T@b?BigGrover
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama -
@JimTrish88, there have been reported cracks in the Alde reservoir. Give nuCamp warranty a call. Number listed under "nuCamp and Forum Contact" in the Category column on the left.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
I just replaced mine a couple months ago with same issue (2016). Bought new tank and fittings from Alde, they recommend adding two 90 elbows instead of sweeping the hoses to reduce the stress on those nipples. I thought they were adding the elbows at the factory now.
2016 Max S, 2011 Volvo XC60
- 920 Introductions
- 74 Teardrop Groups & Links
