hack to keep door open
Mae
Member Posts: 12
i thought i saved directions for modifying a tent peg to slide into the door hinge and hold it open partially to avoid the awning.Cant find it..has anyone seen or tried this?
No, but I plan on doing this.
https://tab-rv.vanillacommunity.com/discussion/6433/no-more-swinging-door
We've slept in 34 states, 2 countries & counting -
@Mae, here is one post on keeping the door open: https://tab-rv.vanillacommunity.com/discussion/2792/keep-door-open-with-pahaque-awnings-and-visors/p1. And here is another one:https://tab-rv.vanillacommunity.com/discussion/4939/door-hold-solution. And the one you were asking about: https://tab-rv.vanillacommunity.com/discussion/comment/21998#Comment_21998Chris and Alexis-- Roseville, California--2017 T@B CS-S--Toyota 4Runner
@Mae, oops! Already handled!2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus. -
thank you everyone! My hubby came up w/a 5" pvc length and a 45 degree elbow at each end and a bungee keeping the door snug against it. Diameter is 1 1/4" & not glued together. We put a bit of pool noodle over the top of the door.I will try to get a photo posted.
Be careful of the tent peg hack. It takes very little force on the door to severely damage the door and or the door frame. A strong gust of wind or simply forgetting to remove the peg could ruin your whole day.
- Hash T@B Fun
I was just thinking a Bungy cord. Think the tent peg hack could cause major damage/strain.
SueBC
British Columbia, Canada -
I just tied a fixed loop in the forward guy line (that runs from the visor rim to the lower keder rail) and loop it over the inside door handle (with the door open) — It’s in a perfect place and gives enough nothing will break or bend.2018 T@B 320 Boondock
2018 Nissan Frontier
Kennebunk, ME USA
- 919 Introductions
- 405 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
