Pam and John
Champlin, Minnesota
2018 T@B400 and a 2025 Ridgeline Trailsport
Yep, I've read the User Manual at least three times. . . seem to understand the basics now & Love It for both space heat and Hot Water . . . nice design, glad NuCamp added it to these great trailers.greenjacket said:. . . finding it a little challenging to navigate the Alde system. Glad its not just us!
With your propane tank open, on the Alde turn on propane and the electric to # 2. The hot water automatically heats anytime you use the Alde if the Alde tank has water. Heating up water faster in this way is contingent on cabin temperature, that is the propane will kick on if the cabin temperature is a couple degrees below what is set. So, if you turn the thermostat way up above the actual cabin temp you will cause the propane to kick in.
