Anyone using this while camping & have any opinions or advice about its utility or worth?
New weBoost Drive 4G-M 470121 Cell Phone Signal Booster for Your Car & Truck – Enhance Your Cell Phone Signal up to 32x
https://www.amazon.com/dp/B07CVLDTJJ
2 ·
I also bought the truck antenna and have attached it to a painters pole with the intention of using it as an antenna for the T@B when I'm parked for a few days. However, I'm not sure that this was the right antenna to buy.
There is a sticker on back of the device which says in very tiny print "BEFORE USE, you MUST REGISTER THIS DEVICE with your wireless provider and have your provider's consent." I wonder what Verizon would say about that? My guess is they'd probably want to make you pay extra for the privilege.
Plugged in to socket above sink. I like that the power plug has a rocker switch built-in with indicator light. From there, the cable runs on top of the window, which seems to support it well enough.
At the opposite end of the window, I installed some cable ties in the corners.
I only put the screw through one side, to make the mount temporary, in case we want to use it in the car.
I mounted the amplifier on the wall above the door, because it provides a strategic location between the power source in kitchen, the outside antenna whose cable goes out through the doorway, and the inside antenna mounted in the rear, whose cable is seen running above the side window.
Inside antenna mounted at center line above the rear bench seat near location of cell phone usage.
This location also allowed excess power cord & transformer box to be stored in the corner of the cabinet.
The amplifier box rests on the top of the door frame, so I only needed to install two hanger bolts to fasten it in place. The hanger bolts have a wood screw on one end & threaded bolt on the other end where I used a capped nut for either a temporary or permanent mount that is easily removed by hand.
Since there is no metal roof outside for the magnetic antenna, I added a metal "ground plane" to my painter pole TV antenna mast by adding two L-brackets to the TV antenna's U-bolt mounting for bolting on an old baking pan made of ferrous metal to reflect the signal to the antenna.
Because the amplifier is close to the doorway and near the antenna mast location, I should be able to get at least 10ft of height above the roof. To be tested soon.
I think that @Verna might also use a WeBoost.
I have seen on the manufacturer's site that for mounting on a non-metal surface, you only need a 4-inch diameter piece of ferrous metal underneath to reflect the signal up into the magnetic antenna.
The metal “L” brackets will act as a reflector and distort the omnidirectional performance of the antenna. With a reflector configuration it will require rotating the antenna to peak the signal.
2018 Tab 400
2019 Tundra CM
Wisconsin
https://www.weboost.com/accessories/outdoor-antennas
I am using it right now and went from 3g with 1 bar to 4G with 3 bars, which made the difference whether my browser was connecting or not. Based on direction I believe the nearest tower is located from this campground, I thing I'm using one side of that plot. Not sure I want to redesign, but at least now I know how to plan for that limitation.
https://www.wilsonproway.com/wilson-weboost-470210-drive-4g-x-otr-cell-phone-signal-booster-for-trucks/?gclid=Cj0KCQjw08XeBRC0ARIsAP_gaQBxS19_XeVcseEptmh6rpca7sI1jIH0msbpwyqaqqWlT43vR_iVrsQaApodEALw_wcB
A friend of mine has the same booster minus the trucker antenna, just the little antenna and he can't make a phone call in remote areas. I can park next to him and use my phone inside my truck just fine with the better antenna. A good antenna is everything...
On my T@g I used (2) 8ft threaded black pipe from Lowe's to get the antenna in the air and using a Wilson Yagi antenna. I welded a 3/8 collar plate that I bolted to the (3) bolts around the tongue. I then threaded my antenna pole into the collar. I used a tagline to help control the sway in strong winds. You have to have some signal to be able to boost it, you can't boost nothing. Don't look at the bars on your phone, go into your settings/about phone and look at the actual true reading the phone is receiving. I use (2) free apps to help aim the Yagi antenna... Open Signal and Network Cell Info Lite. Just aiming at the closest cell tower you see doesn't help. You need the closest tower of your provider. I also swapped the AC power supply for the 12v version so I could make a call without needing electricity.
As a backup I always carry a Garmin InReach GPS with satellite texting. In areas and parks with no service, I link my cell phone via bluetooth to the GPS and am able to text back and forth and receive weather updates. I just need a clear line of site of the sky. I usually place the gps in the window and then text on my phone through the Garmin app like normal...
On the higher powered boosters there is a distance you need to keep between the two antenna (inside and outside). This will be lined out in the manual. On the higher priced boosters you'll have lights or a display that will tell you if you're up to optimal performance.
I use an old horseshoe inside my T@B for a ground plane. Yes, it goes against all I was ever taught about a ground plane, but it works. Check out the above link for my original write-up.
I had better luck the first day I tried the booster last week, but over the next few days found the signal to be quite spotty at the campground in the mountains - sometimes there & sometimes not. Not sure if the weather had anything to do with it, or maybe playing with the antenna direction didn't help. In any case, I think I will be adding this..
https://www.wilsonproway.com/wilson-314411-4g-3g-outdoor-pole-mount-directional-lpda-antenna-50-ohm-n-female/
Correction, this one, because it's much cheaper..
Wilson Electronics Wideband Directional Antenna 700-2700 MHz, 50 Ohm (314411) https://www.amazon.com/dp/B00J14YEHQ
Hey @Verna, do you think Elsie in the Parts Dept could send me one of those Amish horseshoes?
I got the Wilson directional antenna on Amazon, and it comes with two U-bolts & hardware for mounting it to a pole.
Also found these two additional parts needed to connect this Yagi antenna to the booster unit. (Because the cable that comes with the booster is not detachable from the little magnetic car antenna).. This is the same type cable but longer & has connectors on both ends..
● Superbat RF coaxial SMA Male to SMA Female Bulkhead RG174 15ft Cable https://www.amazon.com/dp/B07FC8PVZS
And this adapter connects the above cable's SMA female connector to the antenna's larger N-type female connector..
● Maxmoral N type Male To SMA Male Convertor Wi-Fi Adaptor Connector https://www.amazon.com/dp/B01MFHRW4N
And since the cable is the same thin flexible type RG174, I plan to still run it out through the doorway, which has rubber gaskets to protect it from sharp edges.
Hoping to have at least one last chance to try it out at a campsite before shutting down for the winter.
I have both the omni-directional and trucker ante mas but have yet to use them since I am working remotely and have not bothered to use them on vacation.
I also used the apps as well as scouring the web to find areas with documented good reception.
I also have the Garmin inReach and it has been useful to check in with loved ones when totally off of the grid.
I see more and more where boondocking site abuse has led to shut down of those sites. I hope there are still plenty left when I am free to roam, again.
I worked a bit to try and decode the differences. Some folks here on this site (as well as this article) talked about different antennas (and that's super useful info.. like considerations for grounding plates, window mount vs magnetic, directional vs omni etc..
However I either missed or the info wsn't mentioned.. what's the deal with all those nuances with WeBoost models...
It looks like a lot of it has to do with the antenna system .. some kits meant more for car/truck use have a cradle for the phone.. likely deliberately low power internal antenna for said cradled device.. vs some models that are more RV or even house friendly with more powerful internal antennae
However, I finally found one big difference.. what's the X vs M designation.. these models look SO similar .... and I found a blog page at the manufacturer that does a great job
after reading that article I'm going to concentrate my own efforts on a 4gx model.. now to figure out if I want to do the "Moving" vs "stationary" setup (omni antenna vs something I have to directionally point, but with the benefit of possibly pulling out a bit more signal from distant towers)
If I can work out a decent speed connection, can find ways to reduce my bandwidth usage on most days at work (save the heavy bandwidth stuff for the .. "in park with hookups and wifi" or "plonk down at Panera/McDonalds/Starbucks/etc and use their wifi for a bit" .. I think I could really pull off being able to work remotely a lot.. like not full timing, but good golly I could make sure I felt I was getting my money's worth out of Binky in short order
2019 T@B 320 S Boondock Edge named "Binky" | TV: 2016 Chevy Colorado Z71 with full tow package and a Leer Cap for lots of storage
