We are going to do some Fall camping this weekend at North Higgins Lake and tomorrow night is suppose to go down to 30 degrees. I currently have 2/3 tank of fresh water and was wondering what to do. Should I empty it for one night and refill it in the morning? Should I not worry about it being that low for a night, with the next night being above 32 degrees?
Bob
Richmond, MI
2019 T@B 320 S
0 ·
J.D. & Sue
We were out in Utah this past spring at elevation and had several nights of temperatures dipping down to the high 20s. It was not sustained temperatures. We kept the heat on, the bathroom door and cabinet doors open and put some antifreeze in the P-traps and down to the waste tank valves, just in case. The CS plumbing line runs are all in heated spaces, with the exception of the main supply from the fresh tank to the pump running under the floor above the black, corrugated undercover.
Richmond, MI
2019 T@B 320 S
Richmond, MI
2019 T@B 320 S
The bottom line is that I think you're fine, as long as it gets into the 40's or higher during the day, as it does by me.
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
Richmond, MI
2019 T@B 320 S
The dog hasn't wanted to go out in the morning for a few days now. Maybe that's a sign!
I've camped when the temp only hit high 20's and low 30's for a few hours and the dogs outside water bowl didn't even freeze.
Have fun!
Sold 2023 Tab 400
Sold 2018 T@B 320S
For you folks on the east coast, plan your winter vacation in Alaska!
(Disclosure: I still have our T@B well winterized and will cover it soon!)
Fergie
