Alde water level
Tea
Member Posts: 41
How do I know there is a sufficient amount of water in the Alde (3010) before turning it on?
2017 320-S
Once you have a steady stream of water coming out of the hot tap with no air sputtering, we assume the Alde hot water tank is full (except for the allowable air cushion). I asked the same question😁Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
And even if you turn it on without water in it, there shouldn't be a problem. Many owners still use it for cabin heat after the plumbing has been drained for winterization.
Thank you very much Sharon and Scott. This is all new to me so I have a lot to learn.2017 320-S
Well you've come to the right place! Welcome!
- 920 Introductions
- 74 Teardrop Groups & Links
