Well, can anyone tell me, what's a better way to test it for 'aging'?
Our original Interstate 12V Group-24 "deep cycle/marine" battery seems to be okay still.
To test, I took it off the charger (normally continually connected to the trickle charger), isolated it from the Tab, let it sit for two days, and then checked the voltage. It still reads 12.8 volts (while still completely disconnected from the Tab).
As far as my understanding of dead or dying batteries, this one is still holding a charge, so it should be fine. Am I missing anything?
Is there a better way to test it? Maybe 'under load'?
(I was really hoping to take advantage of the opportunity to upgrade to a twin 6-volt GC2 setup!)
Chan - near Buffalo NY
0 ·
https://www.amazon.com/Schumacher-BT-100-Battery-Load-Tester/dp/B000AMBOI0
But now that it's my turn, and it seems this battery ought to be getting cranky at this age, my simple test doesn't give me enough confidence!
So thanks, I appreciate the input!
https://deepcyclebatterystore.com/use-battery-hydrometer/
I suppose I might do only half of the upgrade I had in mind, replacing the (perfectly good!) 20# propane tank with a pair of 10# tanks. Then when the battery dies, replace that with those two GC2 batteries....
That might be enough to satisfy me...
(Thanks for the suggestion @jkjenn. I guess I didn't realize that specific gravity was enough to go by)
(The moderator said to do it, so, of course....)
Thanks!
Edit: That's 2000, not 200
Well yeah, I've sometimes had good luck, and sometimes not...
But never have I had a battery that lasted as long as 'since 200'!
(Maybe that's a typo?) 2000?
The battery came off the charger 3-4 days ago, and has been sitting disconnected.
Today, two of the cells tested only somewhat low, but another cell tested at 75-80%...
I'll do one more charge-up, with a good Deltran charger, and test it again, but I'm thinking @ScottG was spot on with his scientific diagnosis. "stop pushing your luck"!
Better to deal with it here at home, rather than on the road someplace, away from a Trojan dealer.
Here's what Trojan says in their maintenance guide..
