Please see @dhauf explanation at bottom of this thread:mandt said:...
Does the amount of use have anything to do with the need to replace the glycol?
Should I automatically replace the glycol after 2 years or should I somehow do a ph test to see if there is a problem?
Thanks
ScottG said:Do the pH or specific gravity tell you anything about the anti-corrosion properties? It seems that's the driving force for the frequent changes.
ScottG said:Sounds good to me. Does anybody know what is the pH supposed to be?
ScottG said:Thanks, @ChanW!Should the first line say "below 9.5 is too low"?
