Put "Lagun USA" into your browser. Looks kind of pricey...but it is same price Pleasant Valley charged me two years ago. IMHO you get what you pay for.
lagunusa.com only sells the base, not the tabletop.
Table saw at Sears??? Sorry, I presumed you needed base. Will read closer next time. If you don't want to try making a custom top a cabinet shop could do something for you, or even a fancy breadboard at a kitchen store might work for you.
@blackc2004, nuCamp will probably sell you one. We requested the white Soffitel top for ours when we ordered our TaB. The 320s typically come with the heavy gray top. Call Elsie.
I found some great pre-cut wood at Lowe’s in various sizes that are great for a Lagun table top. I chose a round one, coated it with several coats of stain and varnish, and it looks great. Very easy to screw onto the Lagun.
We mounted it so we could extend it out like the picture, but when rotated 180, the edge was near the vertical stand tube. Easier to use when using the table with T@B in bed mode.
2021 Jeep Gladiator, 2021 tiny toy hauler, Austin TX Former steward of a 2017 T@B S Max
Like Sparky I found a nice 20x36 butcher block item under $20 at Lowes. A little sanding staining and verathane and it looks great. I cut it down to 20x28 so it could also be used as the bed base plus 2 of the end slats. Adds 37% more table surface, reduces weight by 8 lbs vs the orig table plus wood slat puzzle and frees storage space in the seat cabinet and under the bed. It's a 3 way winner!
. . . cut it down to 20x28 so it could also be used as the bed base plus 2 of the end slats.
https://www.amazon.com/dp/B01HQCAJF0
J.D. & Sue
Adventures: 58 Nights: 405 Towing Miles 50,180
My mom's husband made and sold a couple, but he is in poor health and could not continue.
As a bed support
