2014 Little Guy T@B M@X S question
Hello all--Does anyone know if the 2014 Tab Max S has the Aldi for heat or a regular forced air furnace?
Anyone with a 2014 that can add any information as to what's different from the newer ones?
TIA:)
2018 Tab 400
    We have the (September 2013) early 2014.
    They had just started installing the Alde in ours. Ours even came with a hole in the side where the normal exhaust for the forced air furnace would have been.
    So, it could be either way.
    Sorry, no help!
  • lkc001lkc001 Member Posts: 878
    Well, actually that WAS some help, cause now I know that during that time frame some were built with the Alde and some not.. and I know to ask that question from the sellers.
    Anything else that you know of that is different from the newer ones?
    Thanks!
    2018 Tab 400
    If it has an Alde system would it not also have an Alde control panel on a wall somewhere?
    It would be the analog panel in your case, not the digital. The digital panels were started in very late 2015, early 2016, and have been standard since then.
    edited November 2018
    @Ikc001, there are many other improvements and changes that have been incorporated since then also. There are now tank (fresh, gray, black) level (fullness) monitors. Along with a battery charge (state of) monitor. The way the alde transfers its heat into the cabin by way of venting has been improved. Battery shut off switches are standard. The norcold 3-way refrigerator models have been changed. The lagun table is standard since the 2017 models. Front windows are standard now, it was only an option then. Was the front window fixed or did it open? A question to ask.
    Many owners have kept pace with these upgrades by additional venting in the cabinetry, post purchase lagun and battery switch installation, conversion to the digital alde control et al. All of these changes and upgrades can be done with only moderate DIY skill levels, time and some cash. But these are a few of the other questions I would ask a seller.
    @ericnliz, one of my first mods I did I was to change out the analog panel to the digital panel  in my 2014 T@B S Max.
    @Ikc001, I'd also ask how many miles are on the trailer, have the tires been replaced, when was the last time the bearings were serviced and how often the brakes were checked and/or replaced.
    I'm not sure how the Alde venting has been changed, except that now I believe there is no left-hand bench radiator, where ours has left, right, and rear radiators. We open the back lid to let the heat flow out easily, which has the added benefit of keeping the blankets off the rear 'vent'.
    Also, ours came with hydraulic surge brakes, not electric, (but also not the old fashioned mechanical surge brakes either). They changed to electric in 2014 too. I actually think I prefer the hydraulic brakes to electric.
    There have been many improvements over these 4 years, but all relatively easy to add. (Supplemental 'waste heat' exhaust fan in the three-way fridge enclosure. Small exhaust fan in the A/C enclosure)
    Our 2015 had the gas lines resting on the fridge fins problem. Was that in any 2014s?
    Not ours. I think that was a production error...
    :o
    . . . and here I thought I was getting closer to a decision---hahahaaaa!    Just kidding. . .thank you all so much for all the great information.  Sounds like MUCH has changed and I am definitely going to have to take all of this into consideration.  Being informed as much as possible is always a good thing.
    I'll have to make another pros & cons list of "must haves".
    2018 Tab 400
    I have a 2017 320 MaxS. With all the pre-2017 forum posts I read about the norcold venting change I’m very happy with my 2017 with the fins on the right side and vents on the passenger side vs the fins left and vents in front. The issue seemed to be that the front vented fridges created very hot countertops. My side venting fridge doesn’t do this. I guess the flip side of getting a 2014 is you get to modify it to your hearts content, just like the rest of us.  =) Good luck with your decision.
    Homebody-- I found a used 2017 320 S Max that from pictures show fins on the passenger side & two round vents on the front between center & passenger side.  Are you saying that yours is different?  Do all the 320 SMax with the vents like i have described are having problems with the fridge?
    2018 Tab 400
    @lkc001, I have a 2015 with the older (front vented) fridge. I do not believe there is any problem with the fridge itself, it's just that heat buildup on the counter can increase cabin temperatures. Depending on your circumstances, that may or may not be a good thing...  ;-)
    There is a thermostatically controlled fan that moves air over the fridge's cooling fins when needed. nuCamp also provided a free retrofit kit that includes an additional manually switched fan to help exhaust heat out from under the counter. I installed mine myself, but I think they became standard on later models before the fridge was changed.
    Ditto, what @ScottG said.
    It took a bit of experimentation, but I was able to put in some foam board insulation as baffles, and the waste-heat exhaust fans, which reduced the countertop heat to tolerable.
    We have a switch on the fans, to be able to keep the heat inside the Tab in the cooler months, as a second source of heat for the kitchen!
    Great info— thank you all—have any of you that did the fix for the fridge heat posted your fix here with instructions or pics?
    2018 Tab 400
    If you use the search function in the upper RH corner you'll find a lot of info on this fix.
    I'm pretty sure I posted some pix of the baffling I installed. Not sure.
    heh! must be, @jgram2
    I guess the photo I didn't post was one of the baffling.
    Oh well...
    Great info & instruction🤗thanks all
    2018 Tab 400
