Considering VMax V6-225 6Volts 225AH Batteries
gregp
Am hoping for some TAB forum wisdom. Apologies if this has been discussed previously and I have missed it.
I have read in some posts that the WFCO 8735 power center (in my 320s) maybe unable to full charge AGM batteries. Has anyone experienced this? If this is the case, is it specific to VMax brand or all AGM batteries?
WFCO states regarding charging - Automatic three-stage charging extends the life of your battery with output voltage modes of 13.2 Vdc “float” mode, 13.6 Vdc “absorption” mode, and a 14.4 Vdc “bulk” charge mode.
VMax states AC Chargers: Any Quality Brand AGM- Smart & Microprocessor controlled- charger with the recommended specs (not sure what theses are!)
So if WFCO 8735 is not adequate has anyone replaced it with the Progressive Dynamics Inteli-Power 35 Amp Converter/Charger Model #PD4635V? They claim:
BOOST Mode 14.4 Volts – Rapidly brings RV battery up to 90% of full charge.
NORMAL Mode 13.6 Volts – Safely completes the charge
STORAGE Mode 13.2 Volts – Maintains charge with minimal gassing or water loss.
EQUALIZATION Mode 14.4 Volts – Every 21 hours for a period of 15 minutes prevents battery stratification & sulfation – the leading cause of battery failure.
OK, so I am way beyond my liberal arts education so any help and advice would be greatly appreciated!
TAB 320S , 2018 Volvo V90
https://tab-rv.vanillacommunity.com/discussion/7670/should-i-upgrade-the-wfco#latest
@gregp, this discussion will help, I think.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0 -
I have them. Great, so far.
I charge them from the converter when camping but trying to use a Noco Genius when possible.gregp said:@jkjenn, I presume you are refering to the VMax battery? If so are you charging them with the WFCO 8935 and how long have you had them now? Thanks!! Greg2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
I have a vmax tank. The T@b doesnt charge it to more than 13V .I have solar on the roof and it keeps the charge at 14.2 .2015 CS. Ford f150 v8. Southern california0
I had the 2 6Volt Vmax charge tanks in our T@B. Worked great. I reluctantly sold them with the camper.
2007 T@B
Rockford, IL
- 144 Events & News
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
