my Alde won’t heat on propane as I get an airlock error. My book says it has an auto bleeder valve? Or else it hasbleeder screws. Problem is, where are they? My main complaint with this unit is no “ map” !!
i might be able to bleed the glycol if I knew where the glycol tank and the screws or valves are. 2018 320 Boondock Lite. It’s not in the bath compartment behind the toilet unless it’s a grey canister which is also a mystery. Anyone?
2018 T@B 320 Boondock
2018 Nissan Frontier
Kennebunk, ME USA
0 ·
The glycol reservoir is located behind a removable panel on the driver side.
https://tab-rv.vanillacommunity.com/discussion/6085/how-to-get-to-glycol-expansion-tank
The Alde glycol line is supposed to self bleed. You said you can not heat on LPG, what about on electric?
If you can heat on electric, but not on LPG, close your propane tank, then open it slowly. Light the stove and make sure air is out of the LPG line. Then try to start the Alde on LPG with the battery cut off switch turned on.
See above diagram for location of bleeder valve.
Also there is a bleeder valve for the glycol under the passenger side rear bench seat. If you look in the left most corner where the tear-drop starts to go up you'll see a bleeder screw.
Kennebunk, ME USA
And sure, i’ve been on the road since late June and should have checked this out before the sub-freezing nights began, but I didn’t.
I have located the main appliance and see some of the items in the diagram. The auto bleeder on top that has apparently not done it’s job (no adjustments possible on this?), the circulation pump, the hot water stopcock and drain. I haven’t pried away the panel at the back to uncover the glycol reservoir. I’m not clear on whether there is an adjustment screw on it. I also haven’t found a screw in the bottom left corner but will look again. I assume if I find a screw that looks like it’s an adjustment screee I loosen it until glycol comes out then tighten again.
Or or perhaps I find a NuCamp dealer on the road?
Kennebunk, ME USA
Just a suggestion... 😎
Kennebunk, ME USA
Sharon
Automatic Air Bleeder = General Reference
Here are some helpful facts.
Question - 1 -: The User Manual briefly states N.A. units have the automatic air vent installed
however there is no additional information on how it works.
Answer - 1 -: The auto air bleeder has a float that operates a needle valve. If air is in the system
the float lowers and the air is bled out. There is a hose that attaches to this and is directed
through the floor. For proper operation this hose should not be pinched and the hose outlet
under the vehicle should be clear of debris.
Question - 2 -: Do the 'Persistent Air Lock' tips for Single -axle trailers apply/work/help when
the automatic air vent is installed ?
{ reference manual V-3020 XX Rev XXXX, page-13 }
Answer - 2- Part one: My read of tech support answer; Yes, procedure might help clean air locks.
Answer - 2 - Part two: Longer tech support description.
An Alde system is not always installed the same way in every vehicle. Some installations may
have multiple elevation changes, meaning there may be convectors mounted at different heights
and piping runs that are lower. This is why you cannot drain all the coolant just by opening the
drain valve. This can also allow air to be trapped in certain areas. By manipulating the vehicle
position this may allow the trapped air to move in the piping to an area where a bleed valve is
located.
Adventures: 58 Nights: 405 Towing Miles 50,180
