De-lamination
My T@B from Little Guy has DE-laminated in two spots on the side of the trailer forming bubbles, does anyone know how ti fix this?? The dealership was not very helpful, disappointing.
  • lkc001
    lkc001 Posts: 881
    I would be calling Nucamp--letting them know what is going on, let them know exactly what the dealership's response to you was, & ask them what is the path forward to getting it fixed or can it BE fixed?  How old is it?
    2018 Tab 400
  • jkjenn
    jkjenn Posts: 6,424
    What year is your T@b?
    An old comment from CCPIC says he has a 2010 cs
    2020 Tiffin Open Road
    2020 Nissan Versa Toad
    Alan & Patty
    Southern Az
  • CCPICC
    CCPICC Posts: 43
    2016
  • Can you post a picture of your TaB and the delamination?
  • jkjenn
    jkjenn Posts: 6,424
    edited December 2018
    I would get in touch with Austin in repair. They can do it for you or likely coach you some tips. I had the issue and had to replace the sidewalls. Your alumifiber might still be under warranty. It is worth a shot.
  • CCPICC
    CCPICC Posts: 43
    would that be Austin at little guy???  do you have his contact info, thanks!!
  • @CCPICC, Littleguy was the marketing arm of Pleasant Valley Trailers who actually built your TaB.  nuCamp is the company that was created when Littleguy and Pleasant Valley Trailers parted ways.  You should contact nuCamp non-warranty repair.  The contact numbers for nuCamp are listed under the Categories on the left side of the Home page or here:
    https://tab-rv.vanillacommunity.com/discussion/5627/nuecamp-contact-numbers-information#latest
  • CCPICC
    CCPICC Posts: 43
    thank you so much
  • jkjenn
    jkjenn Posts: 6,424
    In my case, it was the sidewall manufacturer's defect.
  • KAR
    KAR Posts: 86
    Our 2015 T@B is doing the same thing:( We'll contact nucamp.
    2015 Tab S with Alde
