De-lamination
CCPICC
Member Posts: 43
My T@B from Little Guy has DE-laminated in two spots on the side of the trailer forming bubbles, does anyone know how ti fix this?? The dealership was not very helpful, disappointing.
I would be calling Nucamp--letting them know what is going on, let them know exactly what the dealership's response to you was, & ask them what is the path forward to getting it fixed or can it BE fixed? How old is it?2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab -
What year is your T@b?CCPICC said:My T@B from Little Guy has DE-laminated in two spots on the side of the trailer forming bubbles, does anyone know how ti fix this?? The dealership was not very helpful, disappointing.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
An old comment from CCPIC says he has a 2010 csjkjenn said:
What year is your T@b?CCPICC said:My T@B from Little Guy has DE-laminated in two spots on the side of the trailer forming bubbles, does anyone know how ti fix this?? The dealership was not very helpful, disappointing.2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az -
Can you post a picture of your TaB and the delamination?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
I would get in touch with Austin in repair. They can do it for you or likely coach you some tips. I had the issue and had to replace the sidewalls. Your alumifiber might still be under warranty. It is worth a shot.
would that be Austin at little guy??? do you have his contact info, thanks!!
@CCPICC, Littleguy was the marketing arm of Pleasant Valley Trailers who actually built your TaB. nuCamp is the company that was created when Littleguy and Pleasant Valley Trailers parted ways. You should contact nuCamp non-warranty repair. The contact numbers for nuCamp are listed under the Categories on the left side of the Home page or here:
https://tab-rv.vanillacommunity.com/discussion/5627/nuecamp-contact-numbers-information#latest
thank you so much
In my case, it was the sidewall manufacturer's defect.
Our 2015 T@B is doing the same thing:( We'll contact nucamp.
2015 Tab S with Alde
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
