Shower shelf and exit assist handle
BogieMeister
Member Posts: 120
At 6'1" I often look like an octopus falling out of a tree when I try to exit the T@B bathroom. While rambling around Lowes I found a combination grab handle and shelf which solves two problems. To mount it I had to add some support to the drivers side of the handle. So I fitted a piece of plywood between the existing studs with pocket hole screws. If you opt to duplicate this be sure to retighten the Pex connections on the back of the shower faucet before buttoning it all up. I found that jostling the Pex pipes around loosened the connection.
Gerri (Gary) Ewing
2018 320 S - "No Agenda Hacienda"
Tow Vehicle 2023 Honda Pilot AWD
Nice...3/4” ply? I’m surprised pocket screws, which I use a lot, can grip enough...
J.D. & Sue
Nicely done...Former 2017 T@G Max XL
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada -
Bumping per request...Gerri (Gary) Ewing
Tow Vehicle 2023 Honda Pilot AWD -
Still my favorite, just don’t have the tools and skill set to duplicate. This is one of those upgrades the factory should incorporate.2019 320s BD Lite, white with blue (“Haven”)
Pacific NW -
I'm short & need an assist bar! That looks great, but is also beyond my capabilities, bummer.
2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab -
Bogie, can you tell me the Lows part number, I love what you did! Art2019 TaB 320 S Boondock Edge
I think I found it!
Moen Home Care Brushed Nickel Wall Mount Grab Bar
2019 TaB 320 S Boondock Edge -
That’s the oneGerri (Gary) Ewing
Bogie I installed it today, thanks Art2019 TaB 320 S Boondock Edge
- 919 Introductions
- 74 Teardrop Groups & Links
