If so, what is your hitch setup? Any issues?
I have the new JL style and it comes with Trailer Sway Damping, but obviously that is just one small component of towing. I plan to use a weight distribution hitch, and I have a lot of ideas on cutting tongue weight on the 400. I found out the spare tire is mounted under the tongue so I plan to move that to the rear of the T@B. I have a Jack-E-Up device that allows the removal of the trailer jack after hooking up to the Jeep. I will be removing the white table in the dinette area. I'm also going to switch out the larger propane tank for a half size one.
My dealership is doing some tongue weight checks on a 400 they have in stock, and I have a call into the Jeep manufacturer to get the exact specs on my vehicle as far as weights and capacities.
Its looking like its going to work out fine. I just wanted to see if anyone else is towing with this setup.
Thanks,
Robyn
Towed by 2019 Ram 1500 Rebel 5.7L Hemi 4x4 Crew Cab
Gladiator, no problem.
Odessa, Fl.
Huntington LI
Then low/no experience user comes in and reads it has been done and tries to replicate the stated success. Hopefully it only impacts low experience person instead of bystanders
IMO it is negligent to post advice that clearly contradicts manufacturer stated limits or capacity for equipment.
Odessa, Fl.
2019 Ford F-150 3.5L Ecoboost with Long Bed
You could not be more wrong. The turbo is insanely powerful! It tows a 400 with absolute ease. I don't even feel it back there. Strong acceleration from stop lights, climbs hills with ease with the 400. Only 1/4" squat on the rear axle with weight distro hitch. I can't even imagine how you came up with that statement if you had actual knowledge of the engine. The turbo is insanely powerful. I will end my comments here. I wish I hadn't even seen your comment. I actually stopped following this thread (and the forum) because I was done with the negative and uninformed comments.
The real issue with towing a 400 which is topic of this thread is the towing capacity as rated by Jeep, not rather there is power under the hood.
I towed a 320 with a JKU and it was a terrible experience. Yup, it could tow it, but driving against a string headwind on a hit day, the engine got hot (yes, I had a transmission cooler.) Towing over the Colorado mountains was slower than molasses in January.
Driving a Grand Cherokee is a night and day difference.
