I have seen the nuCamp video about changing tires using the stabilizers and the tongue jack to raise the tire on a 320. I think though that nuCamp has repudiated this measure for the 320 and even then I have seen nothing about changing tires on a 400. Does anyone know of a "school-approved" method for raising a tire to change it? Does anyone know if there are strengthened jacking points on a TAB 400? It appears that the points where the axle is attached to the frame might be strong enough for a jack. Are there any other points on the frame strong enough for a jack or jackstand?
0 ·
Tire Jack...In Order To Hit The Road...Jack!!!!
THe SafeJack would have to be placed so that it wasn't under the axle housing in case the trailer shifted and it came in contact with the Safejack upper arm but that should be easy to come-up with a sticker to mark that spot off with. Anyone have experience using this Safejack product?
Would still prefer a factory adapter suited to this exact size and placement that would go on top of a scissor or if not that, a bottle jack but until then .....
This SafeJack cradle looks interesting though. I assume you straddle the bracket transversely? I am considering trying to fab something similar that would parallel the axle bracket and turn up under and around the axle and between the frame cutouts without touching the axle. It should also have a lip on the outside to keep the whole thing in position. However, none of that addresses keeping this adapter steady on a scissor jack lifting pad. Maybe some "ears" down around the jack pad?
Still need to figure out the total amount of lift issue though.
Two-Ton Ford Jack Assembly Part #7C3Z-17080-AE
Jack Tool Kit (Handle) #HC3Z-17005-H which replaces 8C3Z-17005-H
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Jeff & Amy
Jeff & Amy
Nissan Frontier PRO-4X (4.6 liter automatic)
Roof mounted solar panels
You could roll the 400 up on a leveling block/piece of wood to gain additional clearance if needed.
My jack arrives tomorrow...thought it would be good to have some safe way to lift either my truck or trailer if needed on the road. The more self sufficient we can be, the better.
San Diego, CA
www.airbossone.com
San Diego, CA
www.airbossone.com
San Diego, CA
www.airbossone.com
