Hi there I am having a problem on my tab 320 S that I purchased in 2018 the battery unless plugged into shore power is not holding its charge when plugged in the highest I have seen it is at 13.6 .
As soon as we unplug from shore power the battery eventually drains down throwing everything off .
The fuse looks intact in the battery box.
The black box just below the seat which I think is the inverter how's the little fan running constantly .
I am not sure what is draining the battery nothing seems to be running in the camper that should be draining it that much that quickly .
I could buy a new fuse and replace it but I'm not sure if that's the problem any suggestions would be helpful thank you
0 ·
You should probably take the battery to a place that will test it and sell you a new one.
When unplugged it drops down to 9.1
I don't see anything wrong with the fuses
Like Sharon said, be sure to figure out what went wrong before putting a new battery in.
"Battery Disconnect Switch (in front tub next to battery)
The battery disconnect switch is used to separate the batteries from the 12-volt distribution panel and converter charging system.
When the switch is turned to ON and the trailer is plugged into a 120-volt shoreline, the 12-volt distribution panel will receive power from the converter and the batteries will be charged through the converter charging system.
When the switch is turned to OFF and the trailer is plugged into a 120-volt shoreline, the 12-volt distribution panel will still receive power from the converter, but the batteries are disconnected from the system. The batteries will not be drained with the switch in the OFF position. The converter will not charge the batteries with the switch in this position.
The charge in the 12-volt batteries can be replenished, depending on the tow vehicle, from the tow vehicle alternator through the 7-way cord. This charge will flow to the batteries, but in order for it to charge the battery the cut-off switch must be turn to ON."
http://tabforum.nucamprv.com/#/discussion/6371/t-b-owners-manuals
As a side note, for utility trailers that would not otherwise have a battery, a small motorcycle battery is usually installed to provide this function. Because some utility trailers use a 4-pin cable (which does not have a charge wire) in lieu of the RV 7-pin cable (which does have a charge wire), the battery may be wired in such a way that the brake/turn lights charge the battery when activated.
Considering a 2023 TaB 400 with the full Lithium option,
2022 Jeep Gladiator High Altitude, Tow Package.
Alan & Patty
Southern Az
I have a 2021 tab 320 S Boondock edge (with a solar system) towed by a 2013 Toyota RAV4.
thanks for your reply! You are on the mark!
