TAB 400 Wheel Hubs
falcon1970
Member Posts: 758
How do the TAB 400 wheel hubs come off? Does the wheel need to be removed first? It can be turned about an eight of a turn but no farther so I'm assuming it doesn't just unscrew.
The wheel has to come off to remove the hub. The hub flares at the base which is captured by the wheel,2018 T@b 400, 200ah Lithium with Solar
2013 Tundra TRD 5.7L
Massachusetts0 -
@DenisP
Thanks. I guess it is time for some jacking practice.0 -
The plastic center cap can be gently pried off so you can lube the hub. do not break the tabs off the cap though.
2018 T@B 400, 2017 Nissan Titan Crew cab0 -
@falcon1970 I doubt you can tighten the decorative tin cap. My Wells Cargo has very similar center caps and they can be a bit loose too, if your wheel is tight not much fixing to be done. Of course if you want to practice jacking and wheel removal, carry on.2019 T@B 400 Boondock Lite1
@atlasb
I guess lubing the axle was where I was eventually going with this.1
