TAB 400 Wheel Hubs
How do the TAB 400 wheel hubs come off?  Does the wheel need to be removed first?  It can be turned about an eight of a turn but no farther so I'm assuming it doesn't just unscrew.
  • DenisP
    DenisP Posts: 542
    The wheel has to come off to remove the hub.  The hub flares at the base which is captured by the wheel,
    2013 Tundra TRD 5.7L
    Massachusetts
  • @DenisP
    Thanks.  I guess it is time for some jacking practice.
  • atlasb
    atlasb Posts: 584
    The plastic center cap can be gently pried off so you can lube the hub.  do not break the tabs off the cap though.
  • N7SHG_Ham
    N7SHG_Ham Posts: 1,261
    @falcon1970 I doubt you can tighten the decorative tin cap. My Wells Cargo has very similar center caps and they can be a bit loose too, if your wheel is tight not much fixing to be done. Of course if you want to practice jacking and wheel removal, carry on.
  • @atlasb
    I guess lubing the axle was where I was eventually going with this.
