My normal procedure has always been to drain my fresh water into the sink, dump the black water and then the gray (all that fresh water flushes well) - Once dumped, I add a gallon of water to the black water tank (along with a bio tab) so it sloshes around cleaning the tank while out on the road. And last, depending on my next stop, I refill the fresh water tank.
But, I got to thinking that maybe I should just leave everything until I get to my next stop (unless that's boondocking) so the black water has plenty of time and road miles to break down the solids with the sloshing. It would mean traveling with extra weight but it would probably keep the black tank from collecting any unwanted solids.
Or, many one could alternate.
0 ·
http://www.thefitrv.com/rv-tips/do-ice-cubes-in-the-rv-black-tank-really-work/
1 Open the dump valve.
2 While valve is open, flush water in tank.
3 While water is flushing in tank, close valve
and count to 100.
4 Shut off water and open valve for final
flush. Close valve.
5 Add water with sewer tablet, unless your
trip is done.
You will have to adjust the procedure for being only one person. We have never had a problem with a black tank in 16 years of RVing.
