Deleting Post Drafts
jgram2
Member Posts: 1,522
Is anyone else having trouble deleting their drafts? I've now tried on an ancient ipad mini, a brand new iPad2, and a middle-aged MacBookPro. When I select a draft, it opens instantly, giving me no time to use the right corner X to delete it.
I have run into that problem, Judi. I can’t remember what I did to make it work except to sneak up on it!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Thanks Sharon, just knowing it can be done gave me new resolve and faster efforts.John, Judi, Guinness & OD in PDX
I have not found a way to do it.
John and Henrietta, Late 2016 T@B S Max in Western New York0 -
On a Mac and PC, I select "My Drafts" from the menu in the upper left (I only see it when I actually have a draft saved.)Clicking that brings me to a list of my drafts. If I hover over one--but don't actually select it--a black x appears in the upper right corner. Click the x and the draft goes poof.2015 T@B Max S (320)
@ScottG , thank you for this post........I had no idea it was there. I found a post that I wrote out once in the past and it had disappeared. I knew I had saved it as a draft, but had no idea where to find it. Spent a bunch of time re-typing the post. Now I know where to go if that ever happens again.
@ScottG Are you hovering with a mouse? On the iPad, I had to almost touch the spot where the X would be appearing only after I touched the words, then actually touch the X and words simultaneously. It required multiple efforts on some of them. But they’re good and gone now. Thanks all!John, Judi, Guinness & OD in PDX
@Bayless, you are welcome. Glad it helped!@jgram2, yes, I am hovering in with a mouse, and it works the same way with a track pad. However, from what you describe, it appears to be a little more challenging with a touch screen (such as on an iPad). I'm not real hip, so I generally work with a mouse and keyboard. :-/2015 T@B Max S (320)
@ScottG -- thanks for this! I was just now trying to delete one and couldn't figure it out. Following your instructions, I found I had several drafts to remove!2018 T@B 320 S Boondock | 2015.5 Volvo XC60 T6 AWD | Seattle, WA, USA
"Blessed are the curious, for they shall have adventures.”― Lovelle Drachman0 -
Thanks! I've been wondering how to do that for some time now!2021 T@b 400 BD "Vixen Gail"
Leadville Colorado0
