jkjenn
Member Posts: 6,417
I picked up my T@b from the factory yesterday. In addition to warranty work, which I will hit on in other threads, I had them upgrade my tires to the Outback tires and install the axel used on the Outback model.
I am guessing it added 2-3" of clearance, overall. The next step will be to move the tire from below the T@b to the tongue.
I don't think there would be much room for a bigger tire.
No rub.
No changes in stabilizers seem to be required.
The step down from the door is a little more of a stretch but I am tall so it won't be an issue. It is just different, nit the completely natural distance it was before.
I am glad this can be accomplished without compromising the look of the T@b.
I had done a quick leveling job yesterday and decided to fine tune it to run the a/c, today. The side with the BAL, which had to be raised was now too tall for the stabilizers to reach. I use plastic pads in addition to the pre-attached feet in the event the ground becomes too soft. To adjust for the gap, I stuck a Lego style leveling block on each if the stabilizers that was too tall and the the plastic pad on top of the Lego block. Problem solved.
Was there anything wrong with it ?
Worth quite a bit on this forum for parts alone !!! Lol
You know, I didn't ask about the old axel. Usually I do, but I guess I didn't have anything to haul it wth.
Parts plus labor came in under $800 for everything.
How do you think the fender clearance will be for driving in snow?
Does the Outback axle have the same load rating?
I'm surprised it wasn't more expensive. Maybe they saw a value to the old axle and wheels.
We'd be interested in doing something like this to help ruggedize ours a bit and were wondering what size tires did yours go to and from? Did you have an older Dutchmen/Thor or a new LG T@B?
I hadn't noticed the Outb@ck have General Grabber AT2 (great tire that we have on our Volvo for winter/off-road duty) and would be great to have a matching set on the trailer. It would be even better if it were possible to fit the 255/50x18 size on our T@B and with a matching Volvo wheel to minimize the number of spares we carry (1 for T@B and will have 3 for our TV - standard donut under the XC90 and two full size spares on top). When they upgraded your axle did they have to lift it from the frame to accommodate a larger diameter tire?
Thanks so much for sharing... it's good to see how much is possible!
With the added diameter on the Grabber AT2 did they need to do anything when mounting the axle to the frame (spacers)? I had thought of doing something similar to our 2006 for added safety of towing on gravel highways. Actually seeing yours is exciting - I had no idea the Outback uses AT2 (great tire we have as a winter/overland tire on our TV). What are its dimensions? Although unlikely it would be even more awesome if they were 255/55x18 to match TV and especially if the bolt pattern matched our Volvo. It would make it easy to have one set of interchangeable spares.
