Sewer hose questions
Yes to both. I use the Flush King and Rhinoflex.
Oh good Jenn - I wasn't sure if they'd be compatible with the T@B's line and also with each other. Will definitely get them now! Thanks - Michele
You never really travel alone. The world is full of friends waiting to get to know you!0 -
Jenn-a stupid question from a new RVer. Do dump stations hoses work with the flush king? Do other RVers mind you taking the time to do this?Cindy with my 2015 MaxS (Puppy) and my 2015 Subaru Outback (Boo)0
The flush is a standard hose connection, so all of thrones I have come across so far have worked.
Truthfully, I have only had people behind me once, when dumping. They made a huge point of telling me to take as long as I wanted. If it were a busy site, I would still use it, but might not take as long as normal. The T@b has such a smaller tank, you could spend a couple of minutes flushing and still take less tie than big rigs. Big rigs rinse their tanks, too. The key is to be aware and try to extend common courtesy.
I have mentioned before, but worth mentioning, again, I like to se the OH Turnpike dump stations, which are free and I have always has tem to myself. It helps to know where te dump stations are along your route.
