Sealing the darn gap between the front of the Tab and the battery/propane tub....
After having gotten the bottom of the tub mostly closed up with a new floor, the gap at the cover's hinge edge has been allowing way too much snow and rain and leaves into the tub, messing up our new battery space!
Home Despot carries a garage door seal that works, it has a slight el shape, it's made for outdoors, so it's probably UV resistant, etc. (hope!)
(It took some nerve to drill holes in the Tab body....)
A carpet & flooring transition edge was perfect for mounting the seal against the Tab body.
The back edge of the cover swings upward when it's closed, and presses against the rubber seal. The rubber is pretty stiff, so it should be good against the weight of wet snow, and hopefully it's also good against the wind while sailing down the highway at 65!
Chan - near Buffalo NY
Yes, good point about caulk, @4ncar. No sense in pressing my luck! But I think I'll wait til the weather is a bit warmer.
We do cover the Tab @Sharon_is_SAM (well, this year was the first year, anyway). And then the weather got so nice, I just had to uncover it (and try to finish the various mods I'd started last fall)... Of course, the next day we had a nice windy snow, which found it's way into every nook and cranny, and reminded me of 'mod priorities'...
I'm pretty pleased with how well the seal turned out. Now I hope it snows again, just to see if it works as hoped!
And I think the dust yer talkin about is the the kind that will find its way through the space shuttle airlock. Hopeless fighting it. Just learn to use it for tooth powder.
You'll just have to come back to the great white north to take advantage of civilization's conveniences!
